help with my cobalt.
davidrforbus
Hey guys I'm new here and I'm having a problem with my cobalt. Its a 2005 4 door. I just installed some aftermarket led projector headlights and now my cluster guage lights are not working and my tail lights airnt working unless I press my brakes. My headlights work but one of the bulbs don't work probably something from the company I got them from. But can anyone help me out? Anyone have a similar problem?
BankDude
disconnect the battery for a half an hour, reconnect it and see if you're having the same problem. if the same problem persists, then try reinstalling the factory headlights and seeing if everything works properly. if those work, but the LED's don't, then you must have bought a cheaply made set of headlights and it's drawing too much power for some reason. did you mess around with the wiring at all?
davidrforbus
Alright ill try the batt. And the only wiring I messed with was three negitive wires that were running to the stock headlight. I had to cut the and I. Wired them back together. I bought them from g-forch-usa on e-bay.
BankDude
did you wire them back the exact way you took them off? because at first i was going to suggest a bad ground wire...and that sounds like what it probably is...
davidrforbus
Well the three wires were running to the exact same place on the stock headlight so I just stripped them back and twisted them together. Figured it'd be the same thing.
BankDude
but were they touching on the stock headlight? not ALL ground wires are black. so i'm just trying to trouble shoot here
davidrforbus
Here's a pic of where they were going.
BankDude
3 wires or two? did you connect the battery yet and see what's up with it?
BankDude
i think you're going to have to figure out your wiring if the battery doesn't make it work
