How do I tape off reverse light for Nightshading?
gCobalt05
North GA
I used painters tape the first time but didnt come out too well.
Any pointers?
How do I get the tape in a perfect circle?
bryson87
Pell City, Alabama
are you tiniting the whole thing. cause if you are i would just take it out...if not. take and put tape on lightly cut it out dont press to hard maybe?
gCobalt05
North GA
Ive had my tails nightshaded but I am re-doing them so there is absolutely NO nightshade on the reverse lights.
Is this how you make a perfect circle?
dunit121
vero beach
what i did was get a flash light and stick it the light hole. then you just tape it up and mark with a pen your circle wich will be clearly defined and then cut it out w/ a razor and just perfect it a little to make it perfectly round
oo oo i got this one... i used three strips of painters tape overlapped. then used a ball point pen to trace the circle groove around the clear then used a sharp knife to cut it out. I'm sure my knife is sharper then your typical knife so use a razor blade/exacto knife.
TIP be very very careful when removing the tape. also make sure you clearcoat the niteshades or it will peel when sprayed with pressure washer. and then wax them babies!!!
Hailcesar75
Brooklyn, NY
Here's a beter way. Lay some masking tape on a clean table. Guess you would need like two or three strips of it, lay them next to each other so it's approxamite the size of the reverse light. Now, get a protractor and measure from the middle to the edge of the reverse light. I hope u know how to use one. Then draw the circle on the layed tape and cut it with scissors, peel off from table and place on light. Violà
protractor ftw!!! lol
DaveBlank
Beckley, Wv
I knew I should have paid closer attention in 10th grade geometry class. lol
gCobalt05
North GA
Ok guys, I finished!
I put painters tape on, shined a light through the holes and cut it out with a pocket knife.
Thanks for everyone's input!
