Motor/Trans mount identification
2fst4you
I have a broken mount on my 08 cobalt support and I need some help figuring out which one it is so I can replace it.
The mount attaches the engine to the trans. It is located on the passenger side at the bottom/rear of the engine
There are 4 mounts total on the car. Depending on which transmission will dictate which mounts they are, the below image is for the auto transmission.
#1 connects to the top of the transmission under the fuse box.
#6 connects to the bottom rear of the transmission
#11 connects to the bottom front of the transmission.
#17 connects to the passenger side of the motor.
2fst4you
The mount I'm looking for bolts to the trans right next to the passenger side cv shaft
#6 in the diagram actually sits on the driver's side of the car (driver's side of the exhaust tunnel). But that sounds like the rear transmission mount you're looking for.
deaa5395_is
2fst4you
So which one would that be? I don't see what I'm looking for in the diagram or any diagram
