Narrowband Install Question
CFCobalt
the matrix
so here's my question...
do i actually have to have an aftermarket header/dp and install an extra O2 bung to complete the install....or is there a wire i can tap into for the oxygen sensor??
You can tap into an existing I believe, just not sure which wire.
Auburn, WA
narrow band only uses existing o2 sensor wire
its in the main ecu wire loom, dont rem which color though...i have one hooked up at home...
there is a how to with some pics on fail.net...i used it about a yr ago when i installed everything
CFCobalt
the matrix
i looked through it....but its for an 06 and nobody answered the question on whether the 07 was the same...so until i find out...im kinda stuck..
I believe it is, check wire colors. no reason it shouldnt be anyways.
M-Town,AZ
i tapped mine right at the o2 sensor itself.purple wire on the car side of the harness.
There ya go, answer straight from the drugged up kid lol :D get better soon buddy.
M-Town,AZ
haaha drugs are no longer in my system.havent eatin in 12 hours though.im hungry.
