Sully
I have a 2.2 on 2.7 pulley making roughly 300. You want to run that 2.8 pulley you need to do a 6 rib conversion to eliminate belt slip. The strength of belt mean nothing when talking about slip. And you can only get it so tight before you need to add surface area to get more grip. I had moved the alt towards the front of the car, tightened the crap out of it and slew of other things to get rid of belt slip. It doesnt work. You need to swap out your crank, alt, and AC pulley to the SS/SC 6 rib configuration and run a full belt. Look at it this way. You run fatter tires for better traction right? Same deal. By going from 5 rib to 6rib you add 20% more surface of the belt to grab that little pulley.
Tensile strangth is only a factor in belts when you want to discuss them holding the set tension and not stretching out as bad over time. Will a 5 rib last as long at the same amount of tension.... not according to physics. Will it still last a long time, yeah sure plenty of people have done it and it works fine. Im just saying you need to get the 6 rib for more "traction" and it will give a bit more longevity too.
