New rear sway bar!!
not really biggest thing needed is undo the downpipe and your golden, they are cheaper than the rear sways
i thought you had to drop the whole front end?
well, i have had the entire subframe off one of these cars before and have a pretty good selection of tools and such, and it was probly a 4.5/10 difficulty on my scale
you have to take your endlinks off, drop the subframe as far as it will go, remove some plastic to do so, remove both tranny mounts from the subframe, then you have to get in and get the bolts off the mounts and then contort it out...reverse steps to get back in. It wasnt impossible, but def not on the easy list. and if you dont have a good jack and jack stands and a nice socket set, it will be pretty hard.
if this is your first big project on the car, i would be VERY careful cause if somethign isnt put back in right then you will have problems once you get out on the road...if you have worked with alot of the car before, then you should be good to go, you just need to know its going to be a couple hour long project haha
Plea
