Oil return location
michelsl
IL
I have searched but can't seem to find the info I am looking for. Where do you guys that are doing turbo builds on the 2.2 return the oil to the engine? I am not doing a turbo build but am putting a bypass oil filter on my car and need a place to return oil from the filter.
michelsl
IL
Is there anywhere on the stock block that you can return oil that has no pressure?
I believe the Hahn kit returns to a block provision, have a look at their instructions. Should work for what you need.
Or tap the pan.
michelsl
IL
I have tried to find the instructions but can't i guess I will have to keep looking thanks for the place to start.
UncleDave
High in Colorado, in a Valley
One simple way that I have found is to punch a hole in the rocker-arm cover, or to put a connector on the Oil Fill cap. Believe I found these in the K&N for their Oil By-pass.
ReynaldoPa
