po1071 too lean
ionit3
o town fl
so i got that stupid too lean in bank 1 after putting on 2.4 intake manifold, what do u think could be causing it? im assuming vacuum leak but where/how
M-Town,AZ
check your booster hose and all your gaskets.I.E. TB gasket,Manifold gasket.Take carb cleaner and spray it along where the gaskets are.If its leaking the car will start to misfire or wanna die
Also check your gasket fuse:laughing1:
06_ion2
Banned
Lino Lakes MN
that would cause it.. check the maf.. i change the air filter out one day and it threw that code.
but do you have a good idle? doe it act up weird at all?
ionit3
o town fl
no it idles FINE
when we first did it it musta got a little piece of dirt in there cuz it sputterred then musta shot it out cuz it was ok after 2 ta 3 secs of sputtering
ionit3
o town fl
im gunna also check seals in gaskets tomorrow cuz i coulda swore the car had a turbo under the hood when driving a bit today
