problem with coilovers..
dman090
Huntington TX
ok so i installed the front strut assembly perfectly, no problem at all.
go to do the rears, everything goes smoothly
i ride on them for a couple days every thing is fine and dandy
this morning i was coming home from a buddys house and every bump i hear a " CLUNK CLUNK" really loud. i get home and check it and here is what i find..
you can see here where the shock is SUPPOSED to bolt in to
idk how the **** that bolt came out, i tightened everybolt as hard as i could, put my whole body into it.
anyone know where i can get a replacement bolt at?
ff_drift_lol
long island, new york
probably over tightened and stretched the bolt. my impact gun puts down like 180 ft lbs and I've snapped some heavy bolts with it...putting all your weight into it is more than your body weight. think about it.
try using a torque wrench and some loc-tite next time. also it looks like that shock is leaking badly or it's just wet. try to get that boot back on if that's not shock oil.
dealer will have the bolt. if it's not in stock grab the other bolt out of the other side, go to ace hardware, get it in grade 8. nice little upgrade and you can tighten the things all you want lol. if I'm not mistaken that bolt also has a tapered end. you just gotta line it up real good when you put it back in if it's not tapered.
oh and use loc tite! do it do it do it!
dman090
Huntington TX
nah it rained for like 3 hrs this morning, everything is wet, thanks for hte advice man
you know where i can get a replaement bolt at? the stock one fell out i guess?
dman090
Huntington TX
thanks for the help man, and ya your right its a tapered end i remember.
i dont think we have an ace hardware down here, you think lowes or home depot would have it?
ff_drift_lol
I think so, but ace is nice cause you just hand them the bolt and they find it for you. 20 minutes later the guy comes back wiping sweat off his face and you walk out 2 dollars shorter LOL
dman090
Huntington TX
HA getting other people to do your dirty work = PRICELESS
They might its worth a shot, could always hit up a junk yard for one too. Any cobalt will have the same bolt. hell even an Ion.
dman090
Huntington TX
god i hate junkyards around here, its just abunch of redneck fuckers that are lazy as hell
worth a try tho
Come to think of it any car with the same rear swing arm (cobalt, ion, hhr) Maybe even a cavi, will have that bolt you need.
