DH10110
So the other day, my 2008 Cobalt LT failed to start on the first try, but the second try started fine. Immediately following, a strong odor of gasoline started flowing into the interior of the car. I was at work on my break at the time, so I had to wait until the next day to bring it into a shop. They lifted the car and found part of the fuel line by the rear driver side was rusted and cracked, with a small drip of fuel as the result (not even enough to notice a difference in fuel levels).
I had the issue fixed/patched by having a friend do what I saw on this forum from countless other threads (using high pressure tubing/hose and a few clamps), and the issue appeared to be fixed. The car started on the first try and there was only a small scent of gas, I assumed it was just the lingering scent still remaining.... I was wrong.
I put an air freshener in the car and lightly sprayed the seats with an odor eliminator and let it sit overnight. In the morning, I let the car warm up (21F degrees in NY this morning) and noticed the smell was still lingering, so I opened the window a crack and immediately the smell of gas started pouring into the car again until I shut the window. Also, note that it is not an exhaust fume smell, it wreaks exactly of fresh gasoline. Any idea's what I can try next?
