Shifter problems
Hailcesar75
Brooklyn, NY
Under my shifter there's a pin that keeps coming loose. When that happens I can't get my key out of the ignition. I know about the buuton under the steering column but it gets annoying to have to do that everytime. Also I can shift out of park without pushing on the gas pedal, or shift into reverse without pushing the pedal too. This makes it very dangerous to drive. Every time the pin comes loose I have to remove the coin tray and lift the shifter tray, stick my hand under the shifter and manually push the pin back into place
has this happened to anyone? Is there a fix to this?
Thanks
gCobalt05
North GA
My girl is having problems getting her key out of the ignition in her Ion too. Been giving her problems since shes had it. Its annoying to sit and wait for it to finally give you the darn key!
if you cant get it out there is a manuel release under the steering wheel, stick your finger in a small hole and feel for a coil, pull it up and the key comes out
ionit3
o town fl
theres a tsb for ION's if i believe correctly also some ION's have to get a new ignition housing (i think thats what it is) check ionforums.net/phpbb3 VERY common prob my ION has the same thing
