Spark issues maybe?
James J
Thornton co
Hey all thanks for your time in advance I have been working on a new motor for my 06 2.2lohv I recently got a ecotec 2.2l out of a 08, I swapped over harnesses from my 06 on to it everything went okay besides the crank sensor and my full coil pack setup witch I replaced to match as well but now im not getting any fire got fuel
Anthony Haarman
Newcomerstown, Ohio
Check to make sure your coil pack itself is good if not that could be the issue if it’s the rail anyway with all of them in one housing or could be the module that sits on the rail itself you could also have a wire or fee that could possibly be messed up so I’d give that stuff a good glance over as long as you’ve already checked all fuses and relays then I would check out those but could always just be as simple as a fuse... I remember having same problem and it turned out to be the coil pack itself so swapped over tested for spark and sure enough started right up!! Good luck hope you get it figured out.. ps definitely check fuses and all first I swapped transmissions because thought old one went bad well new one wouldn’t shift either long story short all it was the whole time was a simple fuse..never over look little things
Staff online
