Stock 12v turn on
Discussion in 'LS, LT, LTZ' started by Jmanjr345, Nov 3, 2018.
  1. Jmanjr345
    Jmanjr345 Junior Member
    3
    Nov 3, 2018
    New york
    I'm trying to wire a subwoofer/amp in my 2009 Chevy cobalt LS. I have a stock radio so I need another 12volt source that is off when the car is off. I've done it in a Pontiac Bonneville and a Honda civic but I cant find one. Can anyone help?
  2. bvqsmgto
    bvqsmgto Junior Member
    67
    4
    Jun 25, 2016
    US
    Get a test light or meter to test wiring
    Sent from my SM-T350 using Tapatalk
  3. mjb
    mjb Junior Member
    19
    Mar 3, 2013
    Florida
    I've got a 2008. Assuming they are the same, there is a kick panel on the passenger side of the console that you can remove to show the fuse box. You can then either find a diagram online or use a voltmeter to determine which one would work for you.
  4. Jmanjr345
    3
    Nov 3, 2018
    New york
    Is that a hot fuse box though? Will it be off when the car is off?
  5. mjb
    mjb Junior Member
    19
    Mar 3, 2013
    Florida
    Some of the terminals turn off, some stay on. You have to test them to find out which does what you need. I forget which one I used (sunroof maybe).
  6. Jmanjr345
    3
    Nov 3, 2018
    New york
    Ok thanks a lot
Share This Page
