Temp Warning Light On & Off
Ricardo Dorador
Lima Peru
Hi everyone, i am having a problem with my 2010 LS coupe the water temp warning light comes on and off suddently with no aparent reason. The engine have the normal coolant level and the fan is working as well... Does any one knows the part number for a new water temp sensor? The check engine is lit as well.
Thanks in advance for your help.
You should get the codes checked, your temp sensor might be fine. That being said you can order a new one from RockAuto.com they're a sponsor here and unrelated are awesome. Think there's a discount code in their vendor section.
Ricardo Dorador
Lima Peru
Thanks I am going to check the codes and I will get back... I already know I having some issues with de VVT Intake Solenoid (P0001 code) but the temp warning light I havent got the car scanned yet thanks!
