Trans Issues
hemylio
Mite just be low on fluid. Happens
Boom. I just checked it. Took the screw off the top, looked in and I could see everything and not much fluid. I work late so I'll be adding a quart or two and posting results.
Sent from my iPhone using Tapatalk
Bass_Waves
I think max is like 2 quarts. Yeah forgot to mention. On the side of the driver wheel. When u take it off. There will be 2 hex cap plugs. Top and bottom. Bottom is drain. Top is fill/level check.
hemylio
Ok. I'll just fill it til I see fluid. When I looked in, I didn't see any fluid at all.
---------- Post added at 01:38 AM ---------- Previous post was Yesterday at 11:57 PM ----------
It's amazing what 1quart can do.lol fixed and no more sounds or delays.
Bass_Waves
Keep an eye on it. You may be leaking it.. glad that solved your issues. ^_^
hemylio
Oh yeah. Also found out the trans pan is skittle damaged so Sunday I'll be replacing it as well as the filter and ALL the fluid in the tranny. Probably doing a small intake mod. Resonator remover and making an intake pipe. This car needs work before it gets a full dip.
hemylio
Not a big fan of it. I just want an all motor tune. Plus how much can stock internals take?
Bass_Waves
A LOT. Maybe all pistons rods and wrist pins is like 1500?
hemylio
Wait so if I just bolt on a turbo I don't have to change the internals?
Plea
