vinyl covered door panel?
would you cover interior panels with black vinyl?
  • Total voters
    4
ford sucks
dearborn,mi
well i painted all the panels black and they looked good for a while but after about 5 months the paint is wearing off in spots.i have been thinking about covering the doors,glove box, panel under the steering column, a pillar and possibly more with black vinyl.
give me your opinion good or bad.
if i do it i would make a how to for it
Tom
Houston TX
Are you capable of this?
there are alot of tough angles, that will be a pain to wrap.
ford sucks
dearborn,mi
well i have wrapped a few things they turned out fairly nice. hell the worst that happens is i buy a set of black door panels or spend lots of time stripping glue off my panel
Tom
Houston TX
yea, i can see the whole door panel being a pain in the ass x100, alot of curves and angles there. but if you pull it off, it well definitely be a upgrade from the plastic look.
ford sucks
dearborn,mi
i would probably do the smaller panels before i do the doors since it has been a while since i covered anything. hopefully it will make it a little easier
cyrusthevirus
Went you paint your panels did you sand them down to be smooth? Or did you just paint over the rough surface?
ford sucks
dearborn,mi
i used gray schoch bright to rough up the surface followed by a wash in dish soap and water after the pannel dried they got a rub down with duplicolor prep spray.followed by dc adheshion promoter then flat black vinyl and fabric paint
i left the textured surface
