10inch sub to stock wiring?
ASmith
Ohio... Need I say more?
So.... i was recently givin a 10in subwoofer in a ported box and was wondering if i could hook it up to the stock wiring on my 2008 Cobalt LS. I have no amp for it. Should i get one? And should I run new wires. Im not to great with audio lol thanks for the help.
newfiedan
SK, Canada
yes what you will need is a line output converter which can be wired into the rear speakers. You will require an amp for it as well as an amp kit. The battery is located in the trunk so wiring is a breeze. The line output converter will give you the rca outputs needed to run to the amp for the sound input.
