2.2 to 2.4 manifold
k_y86
What do u need in order to swap the 2.2 intake manifold to a 2.4 intake manifold? And when swaping over manifolds does the 2.4 intake still accept the stock throttle body from the 2.2 and other connections like a K&N intake. Thanks and any further info would be helpful.
scagnetti76
Helena Montana
''The parts youll need, the 2.4 manifold, crankcase passage seal(seal with metal insert), throttle body gasket, and a power brake booster hose solution.'' -pulled from maven's how to on ecotecforum.com.
check warrenb213's old thread on css.net for part numbers...
bored at work....here ya go. 2.4 Mani, these all I need? - Cobalt SS Network
If it's an 05-06 2.2 you need an adapter plate, PM Cobalt Tom if you need one.
agita_san
Makakilo, Hawaii
Soooo Since I bought the 2.2-2.4 manifold kit off of crateenginedepot I should be all good to go, yeah?
My08
Colorado Springs
What if you own an 08+ 2.2? Isn't there a compatibility issue? Or something like it doesn't make any difference in hp?
08Sedan
Southeast
I'd like to hear more on his question ^
Also, if I buy a K&N intake for my 2.2, then swap to a 2.4mani, will my intake still fit?
the issue i know about was the 05-06 adapter plate...
SAI may give you some trouble if you got it
08Sedan
Southeast
Ok, are there any intakes for the 2.2 that will fit both the 2.2 and the 2.4 manifold?
8balt
