2008 chevy cobalt misfire #1
TIGERBLOOD
hey there guys i have a 2008 chevy cobalt that is my fathers and im having issues with cylinder 1 misfire. I have swapped coils, spark plugs, and fuel injectors, no matter what i have swapped it returns to cylinder 1 misfire. Would anyone happen to have the wiring info so i can test for continuity in the wires from the coil to the ecm, that would be awesome thanks or any common issues that these go through? thanks again matt
Found the connector at the ECU, assuming you've got the 2.2 L61 engine.
Wow, I completely spaced dropping the link to that in my last post. Oops. Here ya go.
- Album on Imgur
Radejr
Have you figured it out? I had cylinder 1 misfire I started with new plugs the light came on again. I moved the coil pack about 4 days ago no light yet. Usually doesn't come in unless I let it idle for about 45 mins or drive it hard. So waiting for that light again see if it's coil.
