tocostew
- Joined
- Nov 1, 2013
- Posts
- 5
- Reaction score
- 0
What would cause the ABS / TC lights to come on? What can I check first?
thanks
thanks
yes, they stay on all the time. I don't really feel much difference in stopping though. Is the wheel speed sensor on the rim or mounted to the frame somewhere.Lots of stuff lol. But if you got both at the same time and they stay on I would speculate that you lost a wheel speed sensor. Any other symptoms? Does the info panel say anything at key on?
great pics, its not a turbo so Ill check the back wheels. I did notice on the passenger side around by the wheel a cable hanging down just a little bit.It's built into the wheel hub. There are connectors at all four corners of the car near the wheel hub. Make sure they are all plugged in. A scan tool might be able to tell you which corner isn't talking.
A common point of failure for the turbo cars is the loom over the back of the engine, that pair goes to the passenger front wheel.
