anything else needed to supercharge 2.2l?
sfwg
tucson az
LSJ supercharger with stock pulley (includes bypass and MAP)
LSJ throttle body
LSJ lower intake manifold with IC in it (includes end plate)
Front mount radiator
IC pump w/ connector & mounting bracket
Upper radiator hose
LSJ tensioner
LSJ belt
LSJ brake booster vacuum hose
LSJ map sensor
33# injectors with EV6 connectors
5/8" hose for IC connections, hose clamps, fill neck
all Bolts
Vacuum line
anything im missing?
sfwg
tucson az
k i knew a tune but #33's rnt big enough for a stock pully? and ill look into the stg2 belt
kandyredcobalt
LSJ throttle body
Upper radiator hose
LSJ tensioner
LSJ belt
LSJ map sensor
all Bolts
Vacuum line
whats an estimated price for this all?
06ion2coup
Columbia Mo
first off almost positive you have to use the stg2 belt and ya 42#er's are what you need, and after that people normall jump to 60
