buick regal gs turbocharged
http://www.buick.com/future-vehicle..._Regal_GS_Concept_-_Regal_GS_|_buick_regal_gs
i want
• 21st-century successor to Buick’s Gran Sport heritage
• Bold, sporty design with unique exterior details and an aggressive stance
• High-output Ecotec 2.0L turbocharged engine and six-speed manual
transmission
• Adaptive all-wheel-drive system and electronic limited-slip rear differential
• 0-60 in less than 6.0 seconds
• Buick’s class-exclusive Interactive Drive Control System
DETROIT – With an estimated 255 turbocharged horsepower (190 kW), a six-speed
manual transmission and an advanced, adaptive all-wheel-drive system, the Buick Regal
GS show car is a high-tech, high-performance version of the brand’s newest sport sedan.
It was introduced at the 2010 North American International Auto Show.
The mechanical elements were developed with the aim of delivering a driving experience
that is sporting, confidence-inspiring and refined. It has a performance-oriented
drivetrain, a lowered body and lower center of gravity. Exterior and interior cues include
two additional vertical front air intakes; large, forged aluminum 20-inch wheels and
performance tires; a racing-inspired sport steering wheel and metal pedals. Recaro highperformance
front seats feature four-way lumbar support and cushion extensions.
“We designed the Regal GS to explore the appeal of a high-performance variant of the
Regal,” said Craig Bierley, product marketing director for Buick. “Like the Regal, the
Regal GS is based on the award-winning Opel Insignia, and we believe it will
reinvigorate Buick’s storied Gran Sport legacy.”
The Regal GS exterior is distinguished by vertical air inlets in the front fascia, as well as
unique rocker panels, an integrated rear spoiler, dual exhaust outlets, Olympic White
paint and satin metallic accents.
“The idea behind the Regal GS was taking the production model in a more aggressive
direction to appeal to performance enthusiasts,” said John Cafaro, Buick design director.
“But along with its aggressive stance, there’s sophisticated style in the design that
complements the driving experience.”
Inside, the Regal GS varies from the standard Regal by featuring a completely jet black
interior, including the pillars and headliner, sport shifter for the six-speed manual
transmission and a suede-covered, flat-bottom steering wheel reminiscent of those used
in international racing series. The instrument panel glows ice blue when the driver
engages the sport mode of the Interactive Drive Control System (IDCS).
Turbocharged AWD performance
Power for the Regal GS comes from a high-output 2.0L Ecotec turbocharged engine with
direct-injection technology. It is based on the engine that will be offered on Regal CXL
models later this summer, but the engine and turbocharger are tuned to deliver greater
boost pressure in the GS. The output is estimated at 255 horsepower (190 kW) and 295
lb.-ft. of torque (400 Nm).
The engine is mated to a six-speed manual transmission that directs torque to an
adaptive all-wheel-drive system calibrated for performance driving. An electronic, limitedslip
rear differential helps ensure the engine’s power is distributed effectively during
cornering.
The high-performance drivetrain is expected to enable the Regal GS to accelerate from
0 to 60 mph in less than 6 seconds. That performance is complemented by a four-wheelindependent
suspension, with a unique High Performance Strut (HiPerStrut) design in
front. The HiPerStrut system helps reduce torque steer and maintain negative camber
during cornering. This improves ultimate grip levels in dry and wet conditions, as well as
improves the direct feel of the road, while isolating undesirable feedback. Behind the
wheel the driver experiences reduced torque steer, improved grip and increased
cornering power, along with crisper handling, steering precision and feedback.
The Regal GS features a high-performance Brembo brake system with 14 x 1.2-inch
(355 x 32 mm) cross-drilled rotors; four-piston, high-strength aluminum calipers, and
high-performance pads.
The Regal GS is also equipped with Interactive Drive Control System (IDCS) chassis
technology (also offered on Regal CXL models with the 2.0L turbo engine). It delivers
enhanced vehicle stability and greater driving safety, while also adapting the driving
characteristics of the car to the driver’s preferences. The driver selects among three
operating modes – normal, sport and GS – that change the suspension settings, throttle
response, shift pattern and steering sensitivity through the variable-effort steering
system.
About Buick
Buick is in the midst of a transformation that started with the Enclave luxury crossover
and continues with the completely redesigned LaCrosse luxury sedan and Regal sport
sedan. Buick is emerging as a modern, premium brand with vehicles characterized by
sculpted designs, personal technologies, luxurious interiors and responsive performance.
Future new sedans and crossovers are planned and will continue to expand Buick's
portfolio both in North America and China. More information can be found at
www.buick.com.
CONTACT(S):
Michelle Bunker
Buick Communications
Phone: 313-815-3345
E-mail: [email protected]
Randy Fox
Product Development Communications
Phone: 313-378-5872
Email: [email protected]
BUICK REGAL GS SHOW CAR SPECIFICATIONS
Overview
Model: Buick Regal GS show car
Body style / driveline: four-door, 5-passenger, front engine, transaxle. All-wheel-drive midsize
vehicle
Construction: steel body-frame integral (unibody)
Engine/Transmission
High-output 2.0L DOHC I-4 Turbo
Displacement (cu in / cc): 122 / 1998
Bore and stroke (in / mm): 3.39 x 3.39 / 86 x 86
Block material: cast aluminum
Cylinder head material: cast aluminum
Valvetrain: overhead camshafts, four-valves per cylinder, continuous variable valve
timing for intake and exhaust
Ignition system: individual coil-on-plug
Fuel delivery: direct injection with variable high-pressure rail and electronic throttle
control
Compression ratio: 9.2:1
Horsepower (hp / kW): 255 / 190 (est.)
Torque (lb.-ft. / Nm): 295 / 400 (est.)
Transmission 6-speed manual
Chassis/Suspension
Front: independent, HiPerStrut-type with dual-path mountings, specifically
tuned coil springs, direct-acting stabilizer bar (hollow); hydraulic ride
bushings; continuous damping control (Interactive Drive Control System)
Rear: four-link independent rear; hollow stabilizer bar; continuous damping
control
Traction control: adaptive all-wheel drive; StabiliTrak electronic stability control
Steering type: hydraulic, variable-effort rack-and-pinion power steering
Brakes
Type: four-wheel disc w/ABS (w/ESC)
Brake rotor diameter (in / mm)
caliper type (front and rear):
14 / 355, vented and cross drilled rotors; four-piston aluminum calipers
Wheels/Tires
Wheel size and type: 20-inch aluminum
Tires: Bridgestone 245/35ZR20
Dimensions
Exterior
Wheelbase (in / mm) : 107.8 / 2738
Overall length (in / mm): 190.2 / 4831
Overall width (in / mm): 73.1 / 1811
Overall height (in / mm): 58.4 / 1483
Front track (in / mm): 62.4 / 1585
Rear track (in / mm): 62.5 / 1587
Interior
Seating capacity (front / rear): 2 / 3
Headroom (in / mm): 38.8 / 985 (front)
36.8 / 935 (rear)
Note: Information shown is current at time of publication. Please visit our GM Media web site at
http://media.gm.com for updates
hmm i always thought that buick should have been canceled instead of pontiac but not so sure now lol
BlackCobalt707
Dover AFB, Delaware
295 est tq? holy shyt. i dont know if i missed it but did it say anything about the weight? my wife and i would both be happy, i get my fast car and she gets her 4 doors
