camshaft position sensor
kimberly
Florida
i have a 2007 ss 2.4 non supercharged. check engine light came on..checked the code p0011...i changed the oil, light went off, came back on two days later. Next step says to change the sensors.Do I have two sensors? And does anyone know what the next step would be after i change the sensor out?
There's 2 sensors and 2 actuators. Actuators are on the top of the valve cover next to the cyl 1 spark plug. Sensors are near cyl 4 but on the head just under the valve cover.
kimberly
Florida
Should I replace all four at the same time? And would you happen to know where I can find part numbers? I went and bought one and it is the wrong one.
Wholesalegmpartsonline.com has great diagrams for parts. You only need to replace one part. Which one is indicated by the code.
glenn Matayoshi
