Wvboy
I haven't gone through and started wire tracing just yet
My cluster/park light fuse blows as soon as you put a new fuse in
I've checked the wires (best I could at the time) behind the glove box and I've also checked the license plate lamp and socket, some corrosion but none to be worried about, I cleaned it for safe measure
My main question before I start tracing wires for a bad ground is;
Will the light or wires to the light under the PRNDL cause the fuse to blow if there is a bad ground there? I have issues with that light working, a lot of times you have to tap that part to get the light to work, figured I'd start there if it was a possible area?
Any help or advice on other locations would much appreciated!
