Cobalt will not Rrun
Ok, here is what I know after a Sunday evening of testing. When I jump 87 to 30 of fuel pump relay the pump runs. So I thought it was just the relay. Changed out with new relay still will not run. So now I am thinking that it must be a fuss link somewhere between PCM and the fuel pump or maybe a bad PCM. What do you guys think?
I have read that many people have had this issue. I am niot getting power to my fuel pump.When I jump the relay under the hood the fuel pump runs and I can start and drive the car, but it just cranks otherwise. I replace the relay that wasnt it, I tried another ground, that wasnt it. I tried leaving the battery off and resetting the code. Has anyone figured out how to fix this yet?
Is the relay installed in the correct spot? It can be installed in the nearby pins accidentally, is your fuel pump fuse intact?
budeuce
