Debadging the rear
Disclaimer: I cant take credit for the how-to, the actual owner is tylerb
There have been a lot of people wondering how to remove rear badges so i figured i'd do a write up on it.
This is really easy and does alot for the look of the car.
i used-
an old credit card(to remove badge) you can use fishing line also.
meguiars body scrub
meguiars wax
hair dryer(optional)-but makes things easier
something to apply wax and body scrub with
heres a pic with the badge
now to start take the line or whatever you are using to remove it and slide it under the emblem. this is when you can use a hair dryer or heat gun to melt the glue a little and make it easier. once you have it removed get all the glue off with your fingers. now take the body scrub and apply it to get the last of the glue off. repeat scrubbing until you think it looks right. once you are satisfied with the body scrub apply some of the meguiars wax and remove. wash car and you are done.
heres a pic without the badge
tylerb
this is my write-up :D...lol
im glad that you guys are saying that its not your original work...
just to add, if you use a credit card to do this put the back side of the card to the paint so the numbers wont scratch your paint.
and the best way to get the glue off is: heat up the glue, spray some goo gone on there, heat it up some more, and then use a old wash cloth or ur fingers to rub the glue off. it comes right off that way
bbrewbaker
Middletown, PA
I used a half bottle of rubbing achool just to get the glue off the rear bowtie.
I was going to take door moldings off.
But that would be a all day project to get the glue off.
Intmd83r
New Hampshire
you can slide the fishingline inbetween the gold and silver to just take the gold part off to paint ..also
Cobaltgirl
My boyfriend and I took the badges off my car. We used a heat gun, but if you decide to use a heat gun make sure you don't keep the heat in one place too long. Cobalt looks much better now without the badges!!!!
---------- Post added at 06:54 AM ---------- Previous post was at 06:53 AM ----------
I also took door moldings off a long time ago. It looks cleaner without them as well.
heat gun works well for the lazy like she said not in one spot to long it will melt through the clear
Brit
yea like a dumbass.. i use a flat head screwdriver and a rag to "pry" the chevy emblem on the trunk off.. and like a dumbass it chipped a little of the paint off. nothing touch up cant fix. so after that! i used fishing wire and goo gone to get the others off. used a little elbow grease and ta da! looks good..
JC, MO
yeah i used fishing wire and goo gone..worked perfect..i also took off the 2 little black stripes that go all the way around the car..looks a lot smoother now
