Egt
Anybody got a ballpark figure on what our max EGT is on this motor?
Preferably what normal is and what melt down is lol
Exhaust Gas Temperature.
---------- Post added at 12:22 AM ---------- Previous post was at 12:22 AM ----------
I like my turbo and wanna know what it normally runs at approx.
1WhiteSSTC
Banned
The Great White North
:weihnachten031: wanna buy me some gauges for Christmas so I can tune in the spring? I need a wideband, EGT, Oil temp, oil pressure, and any other gauge u think might come in handy lol ;) cmon u know u wanna help me murder some cars on the track next year lol
USMCFieldMP
Findlay, Ohio
I'll try and find out for you.
---------- Post added at 07:26 AM ---------- Previous post was at 05:32 AM ----------
I couldn't find anything LNF specific, so I'll just assume that its just like any other car on the road; although I have a feeling the the D.I. might change things up a bit. I'll try and find out more on that though.
800* or so is what it should idle around.
1200* or so when cruising at "city" speeds
1400* or so when cruising at interstate speeds.
1550* or so when WOT at the top of 3rd and 4th.
Ok sweet, wasnt sure if there was a difference for forced induction or anything, thinking I'll get a 2k *F gauge just so I'll have a little buffer at the top end.
Mainly wanted to know so I have an idea of how the turbo is doing, and have a warning before she melts down. Not sure what temp that would be at but I figure its one of the more important things to monitor along with oil temp.
USMCFieldMP
Findlay, Ohio
You shouldn't need anything over 1600*. That's pretty fkn hot and on most cars that I know of, that's The Danger Zone.
1WhiteSSTC
Banned
we should try looking for MS3 EGT's, should be very similar to what we should be running.
Hmm good call White, I'd be all over looking if I actually had my laptop here with me. Stuck on Cobizzle's cause Cobalt Tom's cat ate the powercord lol
USMCFieldMP
Findlay, Ohio
Well, they shouldn't be that different. EGT is going to be effected by a couple different things such as AFR, Timing, and Boost Levels. So no ones Temps will be exactly the same.
Iam Broke
NW Indiana
The EGT values reported by the ECU are calculated I'm told, but I went catless because tuned I saw temps in excess of 1850*f logged in HP Tuners during a hard 4th gear pull at ~22 psi boost. Even if they aren't close to real values, they scared me. This is with the Cat Protection off so it didn't go very rich (.71 lambda) during the pull. I run .88 lambda WOT.
I had a ZZP catted DP on it, but thought it'd become a solid mass at some point.
Iam Broke
NW Indiana
14.7 X Lambda = AFR,
Stoich = 1.0 Lambda
.88 X 14.7 = 12.94 AFR
Stock Lambda is leaner than that by a long shot in the midrange and cruise is 1.0 Lambda or 14.7 AFR.
HTH
1WhiteSSTC
Banned
so what your saying is that you'd absolutely recommend a catless DP vs catted if the person is going to tune/upgrade?
---------- Post added at 11:10 AM ---------- Previous post was at 11:09 AM ----------
cool, i never looked that up. good to know.
see that's why I convinced him to come here :) we need guys with this kinda info on here
Iam Broke
NW Indiana
If you don't have emission testing where you live, or if you are willing to put the cat back on when needed, yes. Most aftermarket cats are good for 1800 - 1850*f EGT's depending on construction materials. Like I said, I don't know how close the estimates from the ECU are, but the catless DP flows better anyway.
ss_coupe_06
