Erro code P0520 and P1516
matarneh81
Hi guys,
I have 2005 Chevy Cobalt LT 2.2 L with 116k. The check engine sign just appeared and when I read the error code they were the P1516 and P0520. Please guys I need your help to know what is these error? and are these 2 problems are serious? and can I drive my car until I get them fixed or it is not good to?
thanks
P0520 is an oil pressure code. Basically your engine is running dry. Check your oil level.
P1516: throttle actuator control (TAC) module throttle actuator position performance.
Basically your throttle pedal isn't reading correctly.
matarneh81
Thanks for your response, Is it harmful for the car to drive it with this malfunction?
---------- Post added at 01:07 AM ---------- Previous post was at 01:00 AM ----------
my oil level is fine and actually the check engine did not turn on for this code P0520 because I have had this error for a long time without the check engine to turn on but it seems the other code P1516 is the reason for the check engine sign.
Oil pressure is a huge problem if it's not working. The other one isn't a harmful one.
