Front end work
pitsnipe
Hampton Roads, VA
Stupid question of the night...how do you remove the sway bar end links from the front struts. I tried to when I replaced the control arm on the passenger side, but the nut and stud both spun together. As soon as I get the new struts in and the third set of rotors and pads I'm going to have to remove the end links from the struts. I have access to only basic hand tools. Thank you for your time.
You should be able to get a spanner on the back side of it. There should be a spot for it. Otherwise you're going to need a lot of penetrating oil and an impact gun.
mdux1982
