FS: complete bolt on sc kit
thought I'd post this...
so i have my setup for sale.
have some different plans for my car...so i will be parting with it.
kit includes :
eaton m62 supercharger. (rotors, gears, and coupler inside came off a wrecked redline with 3k miles).
stock pulley, and 4 bolt hub, with a 2.8" pulley on it
stage 2 belt
42# injectors with harness that plugs right into the 2.2 car
pulley tensioner and idler pulley
lsj manifold (sprayed painted with black heat paint)
lower intake manifold mount and bolt
bosch pump, and pump bracket
cobra heat exchanger
lsj heat exchanger
dual pass
injen intake
option b tank
every gasket needed
all the hoses i used.
all the bolts
upper radiator hose
lsj throttle body
pretty much everything under the hood required to supercharge a car
not going to ship this stuff.
i will be needing the 2.2 manifold, tensioner, belt, stock airbox, stock injectors and harness... and pretty much the stuff to make my car stock again within the same day because my car is my daily driver.
---update----i may be buying the stock parts so i will be able to prolly ship it now.
1500(x3% for paypal fees) with the understanding that I will do the install for you...i can knock it out in a day, and that i get the parts in return.
Haza Newman
5127398304
I am willing to drive to do this install...because I live in an apartment and def do not have the space for it.
I only have minors tools, so a drill and bits and stuff will be needed.
for rules sake....pics
http://www.cobaltss.net/forums/showthread.php?t=148202
go to my build for pics...
goo deal considering he'll install it, i charge atleast 200 for a complete sc install :p
