Fuel pump 2008 cobalt lt
BRENDA J
las vegas
hello im having issue finding a fuel pump for my 2008 chevy cobalt lt 2.2 the one I bought is not the correct one.
Anyone else has had this problem.. ?
SideShow Bob
CO.
Where did you get it from ? Did you keep your receipt ?
Did you contact the seller about a return ?
Does it fit and is just a little different physically ?
Did you check with the GM website to see if there was a bulletin about changing the part from what was original ?
And did you check for any special service order to replace the pump at no charge ?
Read through this thread and look up the special Service tech bulletin, I think in the wording that your fuel pump is covered If is leaking (hint, hint). Read it thoroughly, it covered my gas tank, fuel pump and misc. rubber parts.
https://www.chevycobaltforum.com/threads/minor-miracle-on-13-year-old-cobalt-lt-coupe.27105/
