HEAD LIGHTS
jaamik
texas
I installed complete head light assemblies on both sides of my 2005 Cobalt. I have checked fuses and connections but still don't have low beams either side. I read someplace that in this case the relay that controls the head lights is in the fuse box base. Is this correct? Many thanks.....mike
jaamik
texas
Thanks, five7man..............seems there is a relay under the hood tht controls both sides..........I'll check it out.........thanks, again........Mike
pawntec
Did you upgrade the headlights or just installed the factory housings and standard 9007 bulbs?
jaamik
texas
I'll have to check it out. It's my grandsons care and he bought the parts. I don't know if the parts are aftermarket or OEM....thanks for the reply..........mike
jaamik
texas
thanks for the schematic five7man............I need a "fuse block" that contains the low beam relay
john intili
New Jersey
I have recently experienced a no high beam condition, however in the DRL mode, i can flash to pass and they come on, so it appears that maybe the switch at the column is faulty. I need to check the relay and fuse for high beams. I did install higher wattage bulbs a few months ago.
BTW its a 2009 LS XFE
GBoyd92
