Honda's Clutch Went Out.
wardzach2007
Houston, Texas
My wife has a '92 Honda Accord and her clutch will not work. I looked at it and just wondering what it could be. Probably just need to replace the clutch. Just not sure.
When you push in the clutch it just stays pressed in. The only way you can release the clutch is by moving it back up with your foot. Even if you press down on the clutch you still can't move it into gear.
DaveBlank
Beckley, Wv
sorry dont know what it is....maybe your chevy sabotaged it? do they stay in the same garage? lol
Is there a puddle of brake fluid under the car? Sounds like you leaked out all the fluid in the clutch master cylinder, try bleeding the clutch till there's no air bubbles and see how she does.
---------- Post added at 12:15 PM ---------- Previous post was at 12:14 PM ----------
Check the master and slave clutch cylinders for leakage before you decide to blow money on new fluid too :D
RJBJR
