No power on the fuel pump fuse when key is on
Agentorange22
Pennsylvania
2007 lsj-t no power to fuel pump fuse but power at fuel pump relay…won’t power fuel pump even if hot wired brand new pump and battery within then same week about two weeks ago (both needed done anyways)fuse is good but changed anyways to check…ran great before this happened
ChronoPulseX
Houston TX
Sounds like a tricky one, dude! You checked the fuse and even hot-wired the pump, but still nothing. Double-check the wiring harness for any breaks or corrosion going to the pump itself. Could be a bad ground too.
TomastheG
