How to find Paint Code
GM Paint Color Code Location:
Usually found: Glove Box or Rear Compartment (15, 18) (Spare Tire Cover / Wheel Well or inside Deck Lid)
Other places to look: Driver Side Door Jamb (6), Passenger Door Rear Face, Left Rear Access Door, Left Rear Compartment Inside Door, Passenger Side Sun Visor, Under Driver Seat (5), or Wheel House (20).
There are so many other places for the paint color code to be located for GM cars, so if you do not see the code on those places mentioned above, we recommend that you check your Owner's manual for your vehicle for the location of paint color code. The Owner's manual does not tell you what the paint color code is, but it tells you where it's located on your vehicle. If you do not have the Owner's manual or the paint color code is illegible, contact the dealer with the VIN number on your vehicle, and they should be able to provide you with the information.
Paint Color Code Looks Like:
Usually a three or four digits and start with a WA, such as WA9795 or without WA such as 9795. If the vehicle is two-tone there will be an “L” (for lower) or a “U” (for upper) before the numbers. Example: WA U-7154 or WA L-348D. GM usually lists two codes on every vehicle. There is usually a two digit code, such as 26.
Hummer H1 paint color code is a 3 digit code such as B25 and does not have a WA number.
GMC also markets other brand cars under their own name. Toyota, Suzuki, and Isuzu are all examples. If your vehicle is one of these, then the code will be found under the actual manufactures color list, not GM's. If you do not know what manufacture produced your vehicle, contact us so we can help determine the color.
---------- Post added at 06:46 PM ---------- Previous post was at 06:45 PM ----------
