problem with alarm
Godik1985
Belarus
It all started when they stopped to close the door with the remote control. However opened perfectly. Then he began to open badly. Only under strong pressure several times. Later stops working and the button. I thought that the problem was battery, replaced no results.
Just making sure I am understanding correctly. Your remote isn't unlocking the car anymore? Do the other remote buttons work?
Bass_Waves
From what I just gathered. The buttons have worn out to the point they don't make contact to the board. OR you broke the board from pressure
I'm betting it's the same problem I had, the buttons just need replaced. $5 on eBay.
Bass_Waves
The gummy thing pad lol. They have like nubs on the bottom
Liz.05LS
CT
I've had to replace my fob keypad 2x already. Lock button wore out on me both times. eBay is definitely the cheapest route.. I think I went through "keylessking" on there and got them for about $3.50 each.
Bass_Waves
That could be a reason. Did entry to get an actual good quality gm piece? Or a used remote. Just swap chips
Liz.05LS
CT
Definitely not used. Shiny and new.. lol Bought the casing and the buttons this last time and did the chip swap. It's definitely not GM quality. Plastic is lighter/thinner feeling. Staring at it on my desk right now and I'm noticing the paint is starting to rub off the unlock button already.. haha
I'll second Liz, it's cheaper and lighter material. Haven't had mine long and no noticeable wear.
