not mine original but needs to be saved from servor issues
so I was unhappy with the seat delete I did before, so Mark Spitz from GM Eternal made this one for me. It fits and looks great, it does not move around when you drive, nor vibrate if you have a system. There are a couple things to know about this if you want to do this, so I'll do my own FAQ/tips/comments of some sorts.
1. Yes, you need to remove the back seats, including the black support bar for the seats.
2. Yes, you can put the stock seats back in.
3. Yes, you can buy this kit from a member, PM if you want details.
4. This kit is a direct fit, no modifications needed to kicker panels.
5. The kit screws into the floor pan with 1/2 sheet metal screws, it will not puncture anything belows. The upper portion screws into the rear sheet metal frame around the trunk opening with 2" sheet metal screws.
"Z" Brackets attached to bottom side of floor piece, then to the floor pan.
Screw "Z" brackets into floor pan
Bottom piece installed
Top Piece fits right in
Screw corners into sheet metal opening to the trunk, used caps to hide screw heads.
And You're DONE!!!
And You're DONE!!!
