removing outer door handles?
jonny_b
i have the sticking locked feeling thing going on in my passenger door. anyone have any tips other than replacement to fix it?
jonny_b
Yeah. I see that now. Lol. Something in the handle is messed up, so it feels locked when it isn't. It just needs a little extra tug and it opens. Something is sticking so i need to check it out before someone rips the handle of the car. I have lubed the latch and handle.
bluebaltz
mine sticks like that because we had a 12 ounce dr pepper explode ... and sometimes in the summer, some of the sugar oozes out of crevices & haunts us again lol
especially does it on the seal of the passenger door
Pull the inner door panel, then the plastic liner back a bit so you can see that handle. Lube everything up.
jonny_b
yeah. i checked it out last night, and will be doing that tonight i think. i'm still pulling it because i am repainting and smoothing out the bad casting on it anyway. so hopefully i don't brake anything......
1ATony
You could try to put a little white lithium grease on it.
jonny_b
Problem solved, but taking the handles off was a bitch! There was no room with the window track in, but luckily i have skinny arms and figured out how to get to the 2 bolts by the lock. Also painted them black, but am going to do a satin clear since i don't like the gloss. But the cable popped of the inner handle on the drivers side. I must not of had it clicked into place fully since i checked it before i put the panel back on. So atleast the outer handles work like a charm now. Lol
Lol nice work. The inner handle is pretty easy to hook back up.
jonny_b
Yeah. The clip is a little bent from whoever before me had it off. But i was also in a hurry and it was dark at that point. But it will be fixed tonight.
8balt
