Running hot
Campobelloman22
08 Cobolt running hot
6 months ago I suspected my cobalt had a
small head gasket leak due to low coolant
and some/little white smoke. I added some
expensive stop leak by manufacturers
directions and my issues went away. I've
constantly monitored my temp and it ran
from 190-205 till now. It gets up to 220-225
or hotter unless you turn the heat off and the
temperature drops below 210. I have no
coolant loss and changed the thermostat
and still have same issue. Temp actually got
up to 240 until I turned heat off. Fan appears
to be working fine. Any ideas?
2008 Chevrolet Cobalt SS Coupe
Campobelloman22
140,000 and no I have not flushed the coolent figured that would mess my stop leak job up or will it
Shouldn't, though I try to stay away from the stuff as it can reduce the effectiveness of the radiator if the stuff gets stuck in there.
roosterk0031
Iowa
If the heat knob is straight up or any to the right the AC is running (at least on my 09) keep it a little to the left, cranking up heat should lower temp.
