Tie Rod and stabilizer end rods
GizmoGearhead07
Walworth NY
I recently blew the clutch in my cobalt and decided to do the swap myslef. during the process of taking everything apart i had to detatch the tie rod ends and the stabilizer bar ends while doing this i got the nuts most of the way off and then the whole bolt started spinning and i ended up having to cut the bolts off. is there a way to stop these pieces from rotating so that i can get new bolts on or do i have to buy all new parts?
BankDude
there should be a bolt on both sides of where it bolts. the ball cap may be covering it, but it's a matter of getting a small wrench or needle nosed vice grip on one side to hold it and spin off from the other side
---------- Post added at 07:44 PM ---------- Previous post was at 07:44 PM ----------
should be a nut on both sides, not a bolt, my bad
BankDude
well then at that point, what you will need is an impact wrench
