What is the best lower spring out there?
07cobaltsssc
Woodbury, MN
I have been debating if i want to get some lowering springs for the car, but i dont know what is the best spring out there, and i dont think i really want to spend the money for some coilovers. I dont want to buy a brand that is not good so i am in need of some help to pick these springs out.
bbrewbaker
Middletown, PA
Thats what i was going to say is Pedlers.
Now if you want really good handling but still stock like ride and also mild drop that puts you at the same height of a stock civic then go with pro Kit.
Here is mine with Pro Kit.
I measured 1 Inch drop in the front and 2 in the rear.
07cobaltsssc
Woodbury, MN
Okay cool, yeah i have the rear sway bar already and i do like the ride of it now, but i want some really good handling. What about the sportline kit? Good idea or not really?
bbrewbaker
Middletown, PA
The sportlines are one the best looking drops. That's what I thought about going with.
But i've heard that the ride real rough due do to the lack of travel.
07cobaltsssc
Woodbury, MN
I really dont know what to go with, some of my buddies are saying spend the money for the coilovers and some just say go with springs, but i do kinda like a rough ride sometimes. I think its going to be between the pro kit and the sportline kit.
---------- Post added at 04:32 PM ---------- Previous post was at 04:13 PM ----------
If i do these springs myself, are they hard to do? Also, will i need anything else done for these springs (other suspension components, alignment) anything else?
bbrewbaker
Middletown, PA
It's not really that hard.
It took me about 3 hours to do mine.
That was with my dad helping. I have done them before so that helped.
You will need to have someone to help with the install.
You will need to get your alignment done afterwards.
To bad your your not in PA because I would help with the install.
Here is the walk through I used.
http://www.chevycobaltforum.com/forum/f20/spring-installation-how-300/
07cobaltsssc
Woodbury, MN
Damn yeah that would be sweet. Alright nice yeah i got a couple buddies that will help and that walk through will help out a lot! Thanks man!
07cobaltsssc
Woodbury, MN
Why what is the difference between the sportline kit and the pedders? Also, do i need to get new shocks when i do these springs??
I've owned both pedders and sportline springs, pedders are a much softer ride but are definitely my favorite thus far. If you decide to go the sportline route Koni Yellow shocks/struts are very recommended.
Sportlines arent the lowest, H&R Sport springs are lower, take a look at user "Cobalt Tom"s car, he is running H&R Sport springs and FE5 shocks on 17" wheels. Handles decent but it is a bit rough since it is so low. Really gotta watch where you're driving with them as well.
but if you add the cost of everything up, you might as well go with coilovers.
only advantage this was has is that you dont have to pay for the struts and springs at the same time. wait till your struts blow and then buy the konis, but if your gonna spend the money all at once, might as well go with coilovers
dont forget rack spacers:)
i never really had a reason to buy rack spacers. i dont have bump steer... or at least i dont know it
Punk
Chris and mike and jared said i should so i got them:)
Rotated transmission mounts would be a good idea as well if you drop on sportlines. Keeps the axles in the correct alignment.
