05 cobalt problems
will22578
My buddy has an 05 cobalt 2.2 and the engine went out at 103k. He bought and installed a 2.2 from an 07. He has the transmission also (auto) and the computer. I knew the computers were different so he picked it up. After the mechanic put the engine in, he has told my freind that he needs to rewire the whole car in order to make it run. I don't know if that is true or not. And finally what should our next step be.
Cliffs:
05 cobalt with 07 engine (both 2.2)
Have both transmissions and computers.
Mechanic says car must be rewired for new engine to work.
Help!!
Thanks in advance guys.
Jmesl8er
NKY
Cliffs:
Help!!
only difference might be SAI, but those were only on california cobalts, think mechanic is trying to pull one over on ya
Actually I think the 07 has a cam position sensor that the 05 did not.
Betting the BCM isn't matched up with the ECU or something hell I dunno.
lilloon
near pittsburgh
07 DOES use a cam sensor, 05 does NOT. 07 has electric power steering, and therefore has no way to drive hydraulic power steering pump since the 07 cam is 1.5iin shorter, and doesnt have a hex pressed into the end of the intake cam to drive the hyd p/s pump.
will22578
Now they are saying its because the wiring harness from the 07 has too many connections and doesn't match up with the old harness from the car. But I am thinking one is the power steering pump as stated above and I haven't seen it so I can't say if there even is more than just that. Mostly it seems the mechanic is out of his expertise on this one.
Jmesl8er
NKY
This^^^
NO cobalt had hydraulic power steering...ever! The problem is the car used different ecu's and doesn't match up to the bcm or conections so it has to be rewired, same as if he installed an lnf or lsj into the car.
-posted via tapatalk
No....cobalts never had a hydraulic power steering pump. Since 05 they have had electric power steering....gtfo
