2.4 throttle body and manifold
09balt
Anybody used if on there 2.2l and if so noticed any much of a difference?
kidd1406
you will need a tune i believe so that alone will cause more hp
sfwg
tucson az
w/ just the 2.4l intake manifold u make 13hp so add the tune and 2.4l tb im guessing 15-20
I dont think the 2.4 TB does a bunch unless you are cammed, and even then I don't think its much. Peak HP numbers are useless, look under the curve if you wanna see actual improvements.
09balt
I'm also thinking about getting a 2.4 throttle body and maifold. There is only one problem i'm not tuned yet but i want to be trifecta tuned my next question is how does it react without a tune?
sfwg
tucson az
just with an intake i get 100-150 mi more per tank and it took the lag outta my throttle response so if u add the 2.4l manifold only good things can happen:)
