CurrFury
Car recently started flashing check engine light occasionally while driving. Car loses power and hesitates on acceleration for a moment then smooths out. Scanner says pending code P0300 which is the multiple misfire. Did alot of reading and it sounds like the ICM is most likely the problem. I checked the plugs look good and the compression is excellent in all cylinders. One problem...where is the ICM? I cant find it! Every picture I find shows it on the valve cover. Its not there. Anyone know where it is or if there might be another problem causing this? Any help is appreciated
