Did you install them correctly? Powergrids are great... but they do need to be installed correctly.
I'm pretty sure I installed them correctly, I followed Will's How to @ ccs.
Which way is up on pedders? Does it matter if they are upside down?
Yes. The Top of the rear springs is slightly smaller than the bottom. The last coil... and the overall width. It'll be slightly BeeHive/Egg shaped. There is also a front & back of the Rear Springs. When you set the bottom on the floor... it'll lean a certain way. The way it leans toward... is the front (AKA, the direction it leans, should face the front of the car).
And yes... if you have them upside down... the rear suspension geometry will be thrown off. They usually won't seat all the way either.
Interesting. Oh well. Mine work flawlessly. The clunking sound is gone... that was my main concern when installing them.
Always bothers me because I couldn't tell when I installed them, I know they are leaning forward but not so sure about the upside down part.
I always had clunking issues, even when stock suspension.
You on pedders?
It does matter, I had one of the rear springs installed upside down and I noticed that it was sitting a little higher than the other side.
Yeah... I couldn't tell at first either.
Interesting.
Yes. 08+ FE5 Struts/Shocks, Pedders, and Powergrids.
And I went through the same problem with my first install of the Pedders. Had both rears upside down. They wouldn't seat all the way... and the rear was a good bit higher. Took them out... looked at them again... and then it was like turning on a light. I saw the slight beehive shape and the rest is history.
ok i got one . brake pedal sticks .. only if i lightly tap the brake like if im going down the highway . if i tap it it dont return all the way i have to pull it just a little with my foot to get the brakelights to shut off . not a sticking brake cause when it does this the car still drives straight . if i give the brake a good jam it returns to where the brakelights arnt on
---------- Post added at 09:08 AM ---------- Previous post was at 09:02 AM ----------
o another one, on the wifes cobalt . when i drove it last when i would get on the brake the cars motor would like stutter a little and the headlights would dim slightly . i was thinking maybe the belt is slipping but the belt dont make any noise ..... any idea on that one lol
Ok i got a question.....its for my wifes cavi though.....when she hits the brake exp if its a hard brake......the car will brake for a second stutter and then go back to braking....she does have abs however this is like a hardcore stutter the car will like lunge out when it stutters
---------- Post added at 09:21 AM ---------- Previous post was at 09:20 AM ----------
Also forgot to mention its not the brake pads or rotors......i had those replaced and the problem still occurs
1st try to re bleed the brakes. Any codes on or stored in the abs module? Also could be the module
I'm not sure I could get mine off the bumpstops if I wanted to flip them over, those suckers were wound a bit too tight.
Interesting.
