Check engine light
turboecotec
If I straight pipe from the headers back will my O2 sensor check engine light come on? If so would having a small high flow cat help?
Sent from my SAMSUNG-SM-G900A using Tapatalk
Yes it will. You can install a pair of spark plug non-foulers on that o2 sensor to negate the issue.
turboecotec
I am having problems putting the non fouler on the O2 sensor. The sensor is too long for the non fouler
Drill out the first one so it fits, use that one first and then put the second one on the end.
turboecotec
Okay I will try. I'll let you know if it works
Basically like these.
Put the spacer on the sensor, then the isolator, then the whole thing into the downpipe. That way you're not risking breaking the sensor.
turboecotec
So I straight pipe the car today and the check engine light never came on. Saved me some money
turboecotec
I got a problem the light did turn on. I put the non fouler on it but I won't turn the check engine light off?
turboecotec
It's fine it turned off already. The non fouler worked
