Daytime Running Lights not running in daytime
sequentious
Ontario, Canada
I've got a 2007 Cobalt LT, no modifications. Just recently I noticed the Daytime Running Lights didn't work. I assumed a fuse was at fault, but upon inspection it looked fine. I swapped it with a known-working fuse with no change.
Lights themselves still come on at dusk and hi-beams still work, so I doubt the bulbs themselves could be at fault (two bulbs failing at the same time would be rather coincidental anyway).
I tried to do some searches, but the only results I get are people trying to disable the DRLs, rather than repair them. Anybody have any ideas on what could be the cause?
camopaint0707
NY
I have the same issue. For no known reason my DRL's shut off. Fuse is still good. I can't help you though cause I went and rewired them completely.
