How To Paint Calipers
Nate101
all they had at autozone is the spray caliper paint, my question is would i be able to just spray it in a cup and paint? im only painting the front two calipers blue, i feel confident i could take off the rotor if i needed but I feel thats a lot of work, I also have a lot of painters tape
yeah, if you want to take a plastic bag cover the rotors and slide the bag directly behind the calipers. tape it down behind the brakes to keep from rubbing foward. use some tape the cover the brake fluid bleeder nipple. another bag around the lower part of the strut. spray some cleaner, let it dry. buff with 200 grit paper, again with 800 grit again with 2000 grit. wipe clean. high heat primer, then color
bbrewbaker
Middletown, PA
I had a friend do his that way. He wanted them light blue and the only blue he found was high temp engine paint in a spray.
Nate101
sounds good thanks guys, i plan on doing it tomorrow so ill try and take pics of how it turns out
Nate101
I decided just to spray the paint into a cup and use a brush to brush it on the calipers, it looks a lot better than i thought it would turn out, granted they arent perfect, ill take pics tomorrow
Punk
would have used high temp but noone had any
I'm just thinking, even if the two paints adhered to each other properly, only one of them has the high temp chemical make up, pretty sure it wont repel heat away from the top layer, and the top layer will eventually peel away from the high temp layer.
