Hailcesar75
Ok. This is wierd. Turned my car on this morning and everything was fine. Back the car up and I'm feeling vibrations. Loud vibrations but when I put the car in drive and hit 2000 rpms the vibrations disappear. Pull up to a red lght and there it goes again. I drive about a mile and then at a red light the vibrations are gone. I don't know if it was cuz the car was cold or what. Once I get to work and park it but with the engine still on, I could here it slightly. I look under the hood with the car on and stick my arm in to see if the cat is rubbing on the sway bar. There's about an inch of free space in between. Ok, so it's not the cat rubbing bbut what could it be. I look under the car and I see the resonator byt the dp connection is slightly down but at the other end is fine.
The question is if when I get in my car does the weight force the cr down and have the cat touch the sway? I did hear the rattle also somewhere onthe middle. Could it be the heat shield touching at the resonator? It's weird. Sometimes it happens and then it doesn't. I'll check again today after work
---------- Post added at 09:58 AM ---------- Previous post was at 09:23 AM ----------
Bump
I know how these thread get forgotten after awhile
Bump
