OnStar VCIM 2009 Cobalt LT
Pmac1234
Could anyone tell me where the OnStar VCIM is located in a 2009 Cobalt LT. I have looked underneath the right passenger side kick panel, the rear seat, and underneath the rear package tray. I thought I found it underneath the rear package tray, but it doesn't look like the OnStar module, it looks like it has somthing to do with the XM. Thanks for the help.
bbrewbaker
Middletown, PA
It's behind the rear seats. Under the rear dash cover.
You have to pull the rear dash cover to see it.
It's with the XM unit.
This. You have to take off the headrests and remove the rear deck cover, its one of the modules back there.
Pmac1234
Rear Package Tray
I have taken off the rear head rests. Held the rear package tray up, put a shop light in there, even took a couple really foggy pictures. (attached here) Even in my most soberest state :) I didn't see anything behind what I assumed to be the XM module. Is there really something behind the XM module? If so I guess the whole package tray needs to come up then. Really, I searched that area pretty good. I can't imagine anything behind the XM. Are all the 09 Cobalts the same regardless of model version? Thanks again for the help.
Pmac1234
Really, are you familiar with the CoStar unit to make the OnStar into a Bluetooth receiver? The plugs that the CoStar unit needs are not in this XM unit, from what I see this unit has just an 8 pin plug and what looks like an xm antenna, the Onstar VCIM should have two plugs and an additional for the high speed line. So far I have not got a definitive answer, so maybe this is a new onstar/xm that nobody has seen yet, but shouldn't it have an onstar antenna plug into it? All I see is what looks like an xm antenna
bbrewbaker
Middletown, PA
That i don't know. I just know when i had the package shelf out when I did my speakers. I thought for sure the XM and onstart antena's were connected to it.
Pmac1234
And you just saw the one unit back there? I just got a schematic with one unit behind the next, but I never saw that, but still, I didn't pull the whole tray out. Maybe I will pull the tray out myself tomorrow. How did you get the tray up? I bent it up to get a peak after I removed the rear headrests, but I did't try to pry it up more after that in fear I would break something. Thanks for the help.
Pmac1234
I am trying to install the Bluestar module so I can get Bluetooth capability through the OnStar system. I think I found it, someone told me it was recessed in front of the XM unit. That's probably why I didn't see it. Anyone have any advice on how to remove the rear package tray? Does it just need to be pried up along the perimeter?
bbrewbaker
Middletown, PA
Pretty much just pryed up. The side panels are in slots in it.
But if you push down on the sides and bend up in the middle you can get it out.
Also once the seats are down the corners of the opening have to come off.
It's not as hard as it sounds. I had mine out in about 10 min.
bbrewbaker
Middletown, PA
I thought all 09 balts came with bluetooth....lol
Nope only if you get the Mylink package that includes Bluetooth, USB port on the HU, ABS, Leather wrapped wheel with radio controls,Leather gear shift, and 16 inch 4 lug wheels.
2010 is the same way. When I got mine I didn't want one with out the package.
Don't know if it was the same for the SS.
Pmac1234
I wish I had that, but I got a sweet deal on a car on the lot they were trying to get rid of. I got the Bluestar installed. it works pretty good, however they are still trying to work out an echo problem. I ran an external usb line into the trunk so that i can easily update the Bluestar module when the new software release comes out without having to take the rear package tray out again. Thanks everyone for the help.
